Marius Rocco
- Roy_01
Re: Marius Rocco
Wow nice, must be a pleasure to drive after all that hard work!
Yoo-Mos
Re: Marius Rocco
Hi Marius, I love all the hard work you have put into your scirocco, looks like an amazing job.Marius336 wrote:
I have owned my Scirocco for 2 years now and have been collecting parts where I can.
If you can please help me I have 2 questions;
I have a Pre-facelift Scirocco GT 58plate, red mfd and mk5 steering wheel with halogen lights.
1) what do I need to do to change my headlights to Facelift R headlights? I have a pair of genuine facelift R headlights and want to fit them, will it be plug and play and code with vcds?
2) I have a facelift steering wheel with 1k buttons and a 1k0 CH module. I can see the you have soldered wires to some points. Do you have clearer pics of this?
Thanks man
Marius336
Re: Marius Rocco
My car is 2011, so i dont know what to do to 2009 car with haedlights.
I have 5k0 steering module, my buttons worked plug and play, i did not solder anything, this pictures i posted i found on the internet.
Yoo-Mos
Re: Marius Rocco
Thanks man!
Did you have to modify or change anything on the headlights to change from halogen to genuine xnenons your 2011?
Marius336
Re: Marius Rocco
yes, xenon adapter for the headlights, change the BCM and retrofit the auto leveling sensor
davidscirocco
Re: Marius Rocco
Marius i need your help. What part number do i need for facelift steering wheel?
I found one that is 1K8419091 and has cruse control buttons? Is that ok? My car is a 2009 but with the first white mfd displays and the newer steering wheel when looking on my obd eleven this is my hardware version 1K0953549CF. Is there something else i much check to see?
Marius336
Re: Marius Rocco
All Steering wheels are the same. you only need to change the buttons.
you can take Golf 7/ Passat B8 / tiguan/ Polo.....
you only need the 1k8 959 442 Buttons
davidscirocco
Re: Marius Rocco
Ok . So in my case i only need the steering wheel with buttons with the part number you sent me ? And will be plug and play or am i gonna need to solder anything?
Marius336
Re: Marius Rocco
on 1k0 steering need to solder the wire like the pictures i posted
mrsavvy90
- I drive a: R-Line
Re: Marius Rocco
Marius, what are you doing to the instruments in this picture ?? I have retrofitted from PFL 2011 R I have these in my car the turbo doesn't show 100% correct as it should on idle mine is 0 and goes to 1.5 bar max on full throttle did you modify yours ?
Marius336
Re: Marius Rocco
on my 1,4 CAXA engine, a chiptuning shop moddify my engine ECU to get to turbo gauge to work.
in my CDL engine, it got flashed to CDLK from facelift, eveyting wokrs like fektory.
The pictures i made, i annable 0-100 Km/h and 1/4 mile messurment inside eprom.
Marius336
Re: Marius Rocco
Upgraded my PLA from 2.5 to 3.0
Marius336
Re: Marius Rocco
Replaced my Dashboard with a Facelift one
mrsavvy90
- I drive a: R-Line
Re: Marius Rocco
very nice I have very smilier setup to you Marius !
when you press the button for parking does it open your camera view or Parking sensor only ?
I ordered the switch do you remember what pin in bcm you connect it to ? thanks
Marius336
Re: Marius Rocco
it only open the parking sensor screen
RVC only open with reverse gear.
mrsavvy90
- I drive a: R-Line
Re: Marius Rocco
Marius could you please tell me where to wire up the parking sensor switch please.
thank you <3
thank you <3
Marius336
Re: Marius Rocco
you have Front PDC sensor?
mrsavvy90
- I drive a: R-Line
Re: Marius Rocco
only rear I am going to install front soon ! I have the sensors in bumper just need to buy the wiring loom, do you know where I can buy from ? thanks
Marius336
Re: Marius Rocco
https://de.aliexpress.com/item/32866042 ... web201603_" onclick="window.open(this.href);return false;
