iain_magic wrote:I'm assuming a cheap eBay clone that claims it works with the Ross-Tech software is probably not a wise move?
You get what you pay for basically. As in other things in life. Your best bet is what you've just posted up about getting someone with VCDS to assist considering you only want to do a few things.
iain_magic wrote:Sand33p - just wondering if you had any luck with this in the end?
I'm new to this site, but I have a 58 plate Scrirocco 2.0 TSI GT and am trying to do exactly the same thing as you - I just wanrt to find out the RNS510 HW/FW version so I can upgrade the firmware (for things like SDHC support, and for better maps with 7-digit postcode entry etc). However, like you, the advanced stetup menu doesn't work, because this feature has not been enabled using a VAG COM thingy.
Did you ever find out what model of VAG COM (or VCDS) you need to do this? There seems to be quite a few on their website! I'm actually an electronic/firmware engineer so I'm slightly embarassed to ask, but I don't wanna buy the wrong one -they're expensive! Can anyone shed some light as to which type I want to be ordering (i.e. HEX-USB+CAN or MIcro-CAN or whatever)?
Alternatively, if anyone has one of these in the Guildford area and can help me enable this hidden setup menu with it, please let me know - I'll buy you a pint!
Thanks,
Iain.
Iain,
Sad to say, I've sort of given up for now. I took the rocco in to a VW dealership and they took it in to their garage and got one of their mechanics to take a look. They came back saying there were no updates available for the car and that there was nothing new to load. I don't really believe this to be the case since I do not have 7 digit post code entry and nor does my RNS 510 unit seem to like the 32GB SHDC card I splashed out on (even though my manual says it ought to work.)
I've got the impression from the posts so far that I should try to upgrade to 130X which is the latest and official firmware update and should be relatively low risk. However I'm too scared I will brick my unit.
I'm only in Heathrow, West London so let me know how you get on!
99p for that, same as I have with my Micro SD card.
I do have an updated v7 maps, but not from a dealer if you get me. I have the offical 5.1 (I think) disc, so if v7 fails, I'll probably go an fall back and install the v5.x one I have.
Sandeep - thanks, seems we are in the exact same boat - I am a bit scared of upgrading the firmware without knowing what version I have etc, I don't wanna knacker the RNS! VW clearly didn't know what they were talking about then - there have been many firmware updates that support SDHC cards, bit annoying they don't seem to be given this information! Cheers bud, not far from me then, I will let you know.
Ryy - that is a pretty neat solution actually, nice one, maybe I'll just go for that instead, plus it'll sit tucked away in the armrest where it can't be seen. As for the maps, I have also "acquired" version 7.1, but not loaded it on yet - do you know if this updated map set alone will support 7-digit postcode entry, or do you also require a certain firmware version to enable this feature?
Just started the upgrade process to maps 7.2 (version 8 will be out in October (ish)) my understanding is that you need to upgrade the firmware to take advantage of new features, as the new units now have 3 HD partitions and not the 2 previous ones. To do this you will need to upgrade the firmware to 38xx first and then to 39xx (if you want that firmware) as 39xx will not partition the drive.
mordred - thanks, yeah I figured this would probably be the case, how annoying.
Can anyone tell me what F/W version I would need to achieve this? My car was registered Sep 08, so I imagine the RNS510 F/W currently installed is pretty old school. Thanks!
ive been trying to update my rns with the vim cd but get a software downgrade message. when i plug in the vagcom it says H50 2840 for my radio. is that not the correct version or should i try installing the 2720 as others have done?
I've managed to upgrade the firmware to 38xx, haven't had a chance to get the upgrade to 39xx yet. However I have reinstalled CD_7333 maps (7.1) but have lost my POI. Anyone else had this? Haven't managed to upgrade to maps 7.2 as everytime I burn a DVD DL it doesn't burn correctly so have ordered some VB discs to see if that makes any difference.
yellowplum wrote:I've managed to upgrade the firmware to 38xx, haven't had a chance to get the upgrade to 39xx yet. However I have reinstalled CD_7333 maps (7.1) but have lost my POI. Anyone else had this? Haven't managed to upgrade to maps 7.2 as everytime I burn a DVD DL it doesn't burn correctly so have ordered some VB discs to see if that makes any difference.
With the 38xx software you need v7.1 or later maps to get POIs working correctly due to the new database format and the v7.0 (7333) maps don't have this. You should get them working again when you get the 7.2 map installed.
My bad, thought 7333 was 7.1, hence why I don't have POIs, I will see about getting 7.1 also as I know the single layer disks work with the car, it is the dual layer that I am struggling with (7.2).
Thank you both for your private messages - I am sorry but I can't reply to them with more messages - I am not yet a full member of this site so I am not allowed apparently - not sure how to change this!
Paralla, to answer your question - no I have not yet tried this - I am a little scared to do it too! What I plan to do is first find out what firmware version I have, then upgrade before attempting to load the new maps on. Trouble is, I don't know how to find out! One company in Guildford can do it, but haven't got round to getting over to them yet, as they only open on a weekday. Perhaps we should just be brave!?
Sandeep - thanks a lot for all your advice, it's really concise and helpful - I am sorry for not getting back to you sooner, but like I say I can't send private messages, and have only just thought of writing on here instead!
iain_magic wrote:Sandeep - thanks a lot for all your advice, it's really concise and helpful - I am sorry for not getting back to you sooner, but like I say I can't send private messages, and have only just thought of writing on here instead!
Be nice to share with the rest of us........
RNS 510 updates are a minefield! I've done a lot of reading and I’m still a bit scared to do anything to mine.
I think I have a Rev-C unit because it has the star button on the top right. The clock is displayed on the screen when I turn it off and I get speed limit signs on the map screen. Pressing the setup button when I turn it on tells me nothing. its a 59 plate.
Does anyone know what will happen if I update the maps to V7.2 without doing anything to the firmware? I really don’t want to brick it. At the moment the voice control, POI's all work great but I'd like newer maps and 7 digit postcode search.
So the question is - Is there a risk of bricking it (or breaking POI's or loosing any other functionality) by simply updating the maps but not the firmware?
No secrets...
"Hey Iain,
I just took the plunge and updated my RNS 510 unit to the 1300 firmware last night. It worked a treat and I've successfully tested the 32GB SHDC memory card. Since I have an 09 'rocco and therefore a 1T0 035 680B version headunit I just upgraded straight to 1300. Given that you have an 08 'rocco, from what I've read so far you will most probably have a "rev A" unit - specifically 1T0 035 680A. Now you'll probably have firmware versions 1000, 800 or 900 installed. I would recommend that you upgrade to firmware version 1110 - available here - http://www.my-gti.com/497/volkswagen-rn" onclick="window.open(this.href);return false; ... rsion-1100 and then finally once this is complete, upgrade to version 1300, which is available here - http://www.mk5golfgti.co.uk/forum/index" onclick="window.open(this.href);return false; ... ic=23779.0
Yesterday I loaded maps V8 which went smoothly but I still don't have 7 digit postcode entry. I guess my maps are more current though.
I was pretty nervous about doing the maps and I don't think I am brave enough to do the firmware. My other half would kill me if I bricked it. When it goes in for a service I'll ask VW to do it for me.
