yeah, I've got spigot rings on the front discs. all comes with the mounting kit if you buy the right one. Rears are a pain in the a**, I still have no idea how I'm going. to mount them. think its going to be a custom bracketParadox1 wrote:Thanks for the reply,
I think you'd need the sprigot rings to put on the hub lip. not sure if the mounting bolts for the from caliper would fit with the rear setup??
Cez's Facelift R Airlift 380bhp Aztec Gold
- In: Pyramid Gold
Re: Cez's Facelift R 380bhp Aztec Gold
Re: Cez's Facelift R Airlift 380bhp Aztec Gold
Hi what drop did you go 50mm or 35mm drop thanks
- In: Pyramid Gold
On which set up mate? I went 40mm H and R springs - H and R ultra low coilovers - AirLift. Coils were set about 60mm lower than stockJohnmichelle wrote:Hi what drop did you go 50mm or 35mm drop thanks
- In: Pyramid Gold
So I came home from slam fest with a top 15 trophy
And wheel colour has changed
I have also been taken on as a sponsor for Drexler Ceramic.
http://Www.drexlerceramic.com" onclick="window.open(this.href);return false;
Got some stickers printed for the rear windows and air tanks
Spent a full day correcting the paintwork, and applying my ceramic coating
Results really speak for themselves when you see the shine.
This weekend I am reinstalling my air tank, adding a second, and reupholstering the boot build. My original build was basic and functional but now I’m after something with a little more ‘show’
- SciroccoCW
- In: Oryx White
Best Scirocco on the forum by far
- In: Pyramid Gold
thank you very much man! [emoji2]SciroccoCW wrote:Best Scirocco on the forum by far
- In: Pyramid Gold
Rebuilt my install yesterday and quite liking the end result. First attempt at hard line, it’s not 100% but it’s not overly far off thankfully.
What do you think?
I ran out of wood and needed the car back on the road so had to improvise with the front half of the install. I will rebuild this at a later date so I can have the compressor and manifold on show.
And the final result looks pretty nice
Tanks need a polish to remove some marks and hard lines are being fully polished in the future, along with tanks colour coded to the vehicle.
A new set of wheels, carbon front splitter, carbon skirt extensions and possibly a carbon rear diffuser are next on the cards. Then to start proper work on the interior
What do you think?
Where do you put the shopping now?
- In: Pyramid Gold
The wife’s got a car for that!toplad wrote:Where do you put the shopping now?
Immaculate!!
- In: Pyramid Gold
thank you!Paradox1 wrote:Immaculate!!
Definitely one, if not the best looking Scirocco R that i have seen. Congrats
I have noticed that you have installed recently air suspension. I don't know if you are a keen driver, but i would be interested to know your feedback in how did the ride/handling change after fitting air suspension. I need the additional height occasionally, therefore i was looking more towards Air Cups. But unfortunately, they cannot be mounted on the rear, because the springs and dampers are separate.
Also, if possible to tell me how high does it rise (max height) from the wheels, i would appreciate it allot.
Thanks!
Thanks!
- In: Pyramid Gold
Thank you for your kind wordsroc82 wrote:Definitely one, if not the best looking Scirocco R that i have seen. Congrats
Thanks!
Personally, I think the ride is slightly harder than lowering springs. I am running the Slam series struts, however if you went for the performance model you have the option to adjust camber and damper stiffness, so if you were worried about handling then I would recommend going full performance struts
Thank's mate!
- In: Urano Grey
the colour is just stunning on this!
- In: Pyramid Gold
Kerscher carbon splitter came
Then I ordered some new wheels
Drexler also sent me out their alloy wheel coat in preparation for my new shoes
Unfortunately I managed to damage an arch with a roller so will have to get that rectified soon. But other than that the exterior is looking good and clean now.
Carbon skirts and diffuser and I think I’m about done on the outside
I’d really like an OSIR carbon spoiler but i can’t find one to suit an R so I don’t think it’ll Be an option. If anyone has any advice on this please let me know
- Zanic L3
Wow your car does look beyond sick. Also want to get a facelifted version
- In: Pyramid Gold
Got back from ultimate stance with some nice pictures and a new boot build idea.
Set out getting that in motion and now she’s complete
Tanks are going the same colour as my calipers in the next week or so, then I’ll set about hard lines to replace the current random plastic connecting lines.
My intention is once I get myself a second compressor, mounting my management in the hole in the centre and cutting holes either side for a compressor each.
Decided to get some lighting up in there as well which has been ordered. Should be here in the next few days, installed over the weekend.
Having to remove the spacers from the rear due to constant rubbing issues and re rolling/flaring the front arches to make way for the tyres.
All in all a successful few weeks and to top it off, I’ve been offered a MYNT Automotive sponsorship.
Anyone wanting any new detailing gear, do hit these guys up at:
http://www.myntautomotive.co.uk" onclick="window.open(this.href);return false;
Using discount code: ‘aztec_r’ for 15% off your orders [emoji1417][emoji1417][emoji1417]
- In: Pyramid Gold
Thank you my man!Zanic L3 wrote:Wow your car does look beyond sick. Also want to get a facelifted version
Saw this at Ultimate Stance and took the below picture.
Really nice to see how the car started man! Mad respect for that.
