Facelifted Scirocco Official Pictures And Details
Re: Facelifted Scirocco Official Pictures And Details
Do the bumpers facelift publication R and r-line) suit precisely without no transformation in VW Scirocco MY 2013?
It together knows no code from facelift for the rear bumper of R-r line with all necessary?
According to the seller that was selling the facelifted R-Line kit in this thread there is no modification necessary. It should fit.
Who it is the seller that was selling the facelifted R-Line kit in this thread?Nospheratu wrote:According to the seller that was selling the facelifted R-Line kit in this thread there is no modification necessary. It should fit.
My apologies, it was under another thread. The sellers link is below...
http://www.ebay.co.uk/itm/171277096766" onclick="window.open(this.href);return false;?
You can message him on ebay to confirm if its a direct fit.
Thank you!
Know does anyone, who it is code for new rear lights of R and it can they are placed in MY2013?
- luisgguedes
For the LED Headlights and Taillights you need the new BCM.
1.4 TSI 160cv Sport DSG7 White
Full led (exterior+interior)
Vag-com costumization
Eibach Pro-kit
Eibach Pro-kit
Can you explain ?BCM ? (What is this)
BCM - Body control module. This module is the central electronic brain of all the systems within the car. Whilst the facelight BCM part number hasn't been published yet previous generation units where approx 280 eur or £250 new.
- Kev
- Administrator
The German VW site now has info up
http://www.volkswagen.de/de/models/scir ... ights.html" onclick="window.open(this.href);return false;
- Kev
- Administrator
The new colours look interesting
I should have my facelift R line rear bumper this week so will see if it's a straight fit. Mountings under the lights look spaced differently but the side and lower mounts look the same. Top of the bumper between the lights looks different but may end up cutting that off and plastic welding the one off the old bumper. Will update once it arrives.phaethon wrote:Do the bumpers facelift publication R and r-line) suit precisely without no transformation in VW Scirocco MY 2013?
We expect with distress to see ean it suits
Quick update on facelift rear bumper and it's a no go.
Lower mounting points are good.
Requires new plastic mounts on the top left and right side but also does not match up with the non facelift light shape.
The facelift rear lights are wider. Distance between lights on facelift is 845mm where as on ours it's 940mm.
Consequently from that I understood they don't suit rightly?
Post some picsDubvrs wrote:Quick update on facelift rear bumper and it's a no go.
Will take a lot of work to get it to fit. Does look like the boot opening is narrower at the lower edge.
Just looking at if I could cut off the top section and plastic weld the old bumper section to match them up.
- Moderator
Curious to know why you want to do this?Dubvrs wrote:Will take a lot of work to get it to fit. Does look like the boot opening is narrower at the lower edge.
Same reason I put a R32 engine in my golf mk2. Because I can.skippy wrote:Curious to know why you want to do this?Dubvrs wrote:Will take a lot of work to get it to fit. Does look like the boot opening is narrower at the lower edge.
- Moderator
Oh well - good luck!
- mazzie_baby
The purple is LUSH.Kev wrote:The new colours look interesting
@mazzie_baby
Follow Dolly's build thread here.... http://www.sciroccocentral.co.uk/forum/ ... 13&t=19772" onclick="window.open(this.href);return false;
