Where did you buy x fog lights ? and how do you replace it ?kenti wrote: *Mod edit snip*
Lamin-x on fogs
*Mod edit snip*
My black Scirocco: *New wheels fitted*
- Nikken
Re: My black Scirocco: *New wheels fitted*
Reason: PLEASE do not quote the ENTIRE post again just post the RELEVANT part!
If you care to read kenti's thread a little further past the first post you get to this post which shows how he laminated his existing fogs himself using lamin-x film & where he bought the filmNikken wrote: Where did you buy x fog lights ? and how do you replace it ?
& if you use the search on the forum: how to replace a fog light
- kenti
Some shots from the VAG meeting this weekend.
Awesome! Those wheels work really well. This is easily the nicest 'Roc I've seen
Golf 7R
Gone: Scirocco R
VCDS available
Gone: Scirocco R
VCDS available
Fog's look awesome! Don't think I could pull off doing it myself.
And actually yeah your whole Roc looks beautiful! Good job
I love the car! I just wanted to ask, sorry if it seems nosey, but at a guess how much did you do the r front and rear bumpers and side skirts for, i really want to do it but cant stump up the £4k that niche want! thank you in advance
- kenti
Thanks a lot, Lloydyboy
Beno19:
My car was ordered as R-line, which includes the R-side skirts and the R-rear bumper. I Only hade to upgrade the exhaust and the diffuser in the back.
The roof spoiler was fitted by the dealer at no cost because they'd told me (in writings) that the R-Line would have it.
The front is another story, you'll have to check with your dealer to get the price on that one with all the bits and parts that goes along to mount it. If you are interested I can see if I can find the part list for the front. To get the lights (DRL/blinkers) working correctly you'll have to do some soldering and use the Kufatec-wiring kit and programming box.
Btw, a shot of a friend's car and mine
Beno19:
Kenti
Need some help with programming my LED DRL's to run as DRL's instead of running as Sidelights and how do i code my DRL's to turn signals. I've got xenon headlights and have installed the Scirocco R led's but need help programming. How did you manage to sort yours out?
Regards
Mo
Regards
Mo
- skoTner
- I drive a: R-Line
What a piece of jewelery! This is the inspiration I needed to go for the R-front...
wow this is a cool scirocco.. where abouts do you order your parts from? exterior and interior. Sorry I am new to this site so go easy on me
- I drive a: R-Line
are you running spacers mate and if not how did you get you wheels so sit flush? car look amazing btw good job !
No spacers, just low offset, 9x19 ET 33markirwin wrote:are you running spacers mate and if not how did you get you wheels so sit flush? car look amazing btw good job !
Is there any way you cap put your black fog lights at the r's front grille??? Like the fotos at google scirocco r cup where the cars are scirocco r and they have fog lights at the front side thank you
- robbieredknapped
Hi Kenti,kenti wrote:Thank you very much for the nice comments, guys!![]()
@longman: Those summer wheels are standard "Gunmetal" color. Mine were replicas, but thay can be ordered in that color from VAG as well.
The new summer wheels were fitted yesterday![]()
Just asking, do you need new longer wheel bolts for the Savanah Wheels? or did you use the original bolts?
- Le Clue
I'm also running Savannah's and using the OEM bolts.
- robbieredknapped
Hi Le Clue, just to confirm, you are using OEM bolt from your original wheels?Le Clue wrote:I'm also running Savannah's and using the OEM bolts.
Looked alot better with the R-Line front tbh :x
- Le Clue
Yes the same bolts that came from the factory with the 18" Interlagos..robbieredknapped wrote:Hi Le Clue, just to confirm, you are using OEM bolt from your original wheels?Le Clue wrote:I'm also running Savannah's and using the OEM bolts.
- robbieredknapped
how much are your front windows tinted?
