I already sent them an email but they are off and they will back in business tomorrow.Paradox1 wrote:You should be able to get them directly from H&R - Drop them an E-mail, they should be able to post you someMostic wrote:The real problem I have is that the front sway bar came without the installation brackets so I have to remove it from the OEM bar and install it to the H&R one which I see something really bad! Any idea from where to buy the front sway brackets?
*.* Scirocco R Build! (Fun, Tough & Cost) *.*
Re: *.* Scirocco R Build! (Fun, Tough & Cost) *.*
http://www.sciroccocentral.co.uk/forum/ ... 13&t=21372" onclick="window.open(this.href);return false;
MKV Build!
http://www.golfmkv.com/forums/showthread.php?t=195173" onclick="window.open(this.href);return false;
MKV Build!
Worth waiting for as you should get them for free.
Have you decided on which turbo to go with yet?
I already have TurboZentrum EFR7163 ready to be fitted back as I had installed it last year before the engine failure. I will put it back but I am planning to go for a larger G30 or G35 turbo and DQ500 conversion. But I should save BULK of money! [emoji1][emoji1]Paradox1 wrote:Worth waiting for as you should get them for free.
MKV Build!
MKV Build!
I just went through you thread again as its been some time youve been working on this project.Mostic wrote:I already have TurboZentrum EFR7163 ready to be fitted back as I had installed it last year before the engine failure. I will put it back but I am planning to go for a larger G30 or G35 turbo and DQ500 conversion. But I should save BULK of money! [emoji1][emoji1]Paradox1 wrote:Worth waiting for as you should get them for free.
If you decided to go for a garret turbo, instead of the GTX3071/67R, look at the g25 660 turbos. New series, supposed to be K04 spool with GTX30 delivery on boost!
It is a continuous projectParadox1 wrote:I just went through you thread again as its been some time youve been working on this project.Mostic wrote:I already have TurboZentrum EFR7163 ready to be fitted back as I had installed it last year before the engine failure. I will put it back but I am planning to go for a larger G30 or G35 turbo and DQ500 conversion. But I should save BULK of money! [emoji1][emoji1]Paradox1 wrote:Worth waiting for as you should get them for free.
I am thinking of the G30-900 or G35-900
MKV Build!
MKV Build!
So 550bhp is no longer the target then hahaha
No more [emoji1] targeting 750awhpParadox1 wrote:So 550bhp is no longer the target then hahaha
MKV Build!
MKV Build!
You are insane lolMostic wrote:No more [emoji1] targeting 750awhpParadox1 wrote:So 550bhp is no longer the target then hahaha
Do you know if the efr7163 fits RHD cars?
I may be in the market for one........
[emoji23][emoji23]Paradox1 wrote:You are insane lolMostic wrote:No more [emoji1] targeting 750awhpParadox1 wrote:So 550bhp is no longer the target then hahaha
I may be in the market for one........![]()
Don’t know if it will fit or not but you can contact TurboZentrum and ask them.
Welcome on board
MKV Build!
MKV Build!
Just testing the waters, I was about to fit my k04 but now revisiting this thread has got me thinking.......
Hi, did send you a message about this but I was looking for some more information about the fuel tank joining & the brackets you bought. I’m in the middle of doing my r32 awd conversion just now
Hi,Chris-mowatt wrote:Hi, did send you a message about this but I was looking for some more information about the fuel tank joining & the brackets you bought. I’m in the middle of doing my r32 awd conversion just now
Sorry for the late reply, here are the brackets part numbers I ordered in order to install the cardanshaft
1K0 804 331
1K0 804 332
Unfortunately I don’t have pics for the tank while welding. You have to cut the Scirocco fuel tank neck and weld it in the Golf R tank neck, and this will need MANY try and error before you reach the right position and dimension.
I wish you the best in your project and let me know if I can help.
Note: PM replied [emoji4]
MKV Build!
MKV Build!
This fault appears after installing the iABED TSi Cam Follower Roller Conversion. I tried to install it without replacing the APR HPFP Spring but the car was misfiring then I installed the spring comes with the kit and the car started giving engine brake in the redline (the car stop by itself like you press the brake paddle hardly) and receive this fault!!
Do you have any idea why this happened?
MKV Build!
MKV Build!
Really impressive build. Big fan of the detail and thought you have put in!
Thanks [emoji4] it become an endless project [emoji23]Telwick wrote:Really impressive build. Big fan of the detail and thought you have put in!
MKV Build!
MKV Build!
Hi, I'm new on this site and found this while searching for ways to get my ABS to accept that my scirocco R36 is awd.Mostic wrote:The cluster has to be patched to change from Scirocco to Golf with a golf chassis VIN too then the ABS coded.Alien_IROC wrote:Very good! So how have you resolved the ABS problem?
I believe that the problem coming from the cluster because it sends the signal that it’s a Scirocco and the ABS can’t accept the AWD that coming from the Scirocco because there is no AWD Scirocco. Once it’s changed to Golf the ABS accepted the coding.
I want to try if changing the cluster itself from FWD to AWD would help and fix it not. I had similar issue with my MKV when I was trying to install a cluster moved out from R32 to my MKV GTI. The ABS didn’t accept coding until I changed the cluster from AWD to FWD.
How did you solve it? I just ordered a Golf R Cluster but my plane is to use the Premium Cluster from Scirocco.
Did you reflash the EEPROM with new VIN, Power Class and enabled AWD? In that case it might be possible to just use a EEPROM flash from a Golf R?
I was busy the last few months planning for the next upgrade step, and I did it!
DQ500, and Nortech G30-900 0.61A/R are completely installed yesterday. I am in the phase of checking the oil, air, etc leaks now; so, I will drive the car for a few days then will back again to the workshop to check them.
I am waiting for TVS Engineering to send the ECU & DSG files this week.
I am running now the Turbosmart Kompact Shortie Plumb Back that I was using with the EFR7163, any idea/recommendation for DV to use it with this turbo setup?
link for the Turbosmart Kompact Shortie Plumb Back
https://www.turbosmart.com/product/komp ... lumb-back/" onclick="window.open(this.href);return false;
MKV Build!
MKV Build!
Quick update..
Decided to back to work on the Rocco, so I gave the engine some shower after doing some leak checks.
Will do data-logging soon to get the proper tuning for fuel pump only before doing the Aquamist WMI.
MKV Build!
MKV Build!
Nice seeing som update!Mostic wrote:Quick update..
I'am at the moment putting a DQ500 in my Scirocco R36, to handle the power.
What bit did you change in the EEPROM to change from fwd to awd?
Good luck with the DQ500 in the R36, I heard it is not straight forward.a6lex wrote:Nice seeing som update!Mostic wrote:Quick update..
Regarding the EEPROM, it is done by a friend of mine who is Canada now. I will try to ask him and get back to you.
MKV Build!
MKV Build!
