Low level Screenwash?
Roy_01
In: Sumatra
Re: Low level Screenwash?
Post by Roy_01 »
Here is a quick installation guide. Keep in mind my car is a right hand driven one and dsg model year 2010.
On the left hand driven ones there will be a difference where you can guide the wiring from the engine bay to the inside of the car.
I also have the 5,5 liter washing bottle installed. It has a blanking plug which can be easily removed to fit the sensor.
Take a look if you have the blanking plug before performing this manual. It's possible you have to drill a hole and install a rubber washer (7M0 919 382) .
These steps are not mentioned in the installation guide.
daves2369
Options: APR Stage 1
Heated Viena Leather,
18" interlagos alloys
RNS510,
Bluetooth 9w7,
Milltek Cat Back,
VWR Intake,
Cruise Control,
Parking sensors,
MK5 R32 345mm Setup,
Headlightretrofits bi-xenon
Post by daves2369 »
Cheers going to give this ago on the weekend!
my only concern is the pinning on the instrument cluster I have the mk5 cluster (red) not sure if the wiring is different or not to the white one?
wensleydale
Post by wensleydale »
I've just been through the circuit diagrams again, and it's the same pin on both the red and white MFD's.
daves2369
RNS510,
Bluetooth 9w7,
Milltek Cat Back,
VWR Intake,
Cruise Control,
Parking sensors,
Post by daves2369 »
wensleydale wrote:I've just been through the circuit diagrams again, and it's the same pin on both the red and white MFD's.
Cheers :) is there anywhere I can get a copy of all the circuit diagrams for the car do you know?
Roy_01
In: Sumatra
Post by Roy_01 »
Im also jealous of your nice wireing diagrams;)
wensleydale
For €5+VAT VW will give you an hour to download as much service and repair documentation from their website as you can:
https://erwin.volkswagen.de/erwin/showHome.do" onclick="window.open(this.href);return false;
It took me around 15mins to download everything for the Scirocco, so you have plenty of time to get what you need.
Roy_01
In: Sumatra
Post by Roy_01 »
wensleydale wrote:For €5+VAT VW will give you an hour to download as much service and repair documentation from their website as you can:
Thats interesting will give it a try. I thought it was read only and not possible to save.
wensleydale
Just a tip for anyone wanting to try this, I checked my washer bottle today, and there was no blanked off hole for the level sensor, just a marking to show where you should drill. It's worth checking before you order parts as you may end up with a more difficult job to fit the sensor.
Roy_01
In: Sumatra
Post by Roy_01 »
wensleydale wrote:Just a tip for anyone wanting to try this, I checked my washer bottle today, and there was no blanked off hole for the level sensor, just a marking to show where you should drill. It's worth checking before you order parts as you may end up with a more difficult job to fit the sensor.
Thanks for your update. I have put this information in the pdf file to first take a look at this sensor hole.
I think only the cars with oem xenons, winterpack or tdi's have the 5,5 liter washer bottles installed which has the blanking plug.
For the hole drilling i found a how to: http://uk-mkivs.net/topic/27803-low-scr ... ng-fitted/" onclick="window.open(this.href);return false;
I used this manual to order all the parts needed for the fluid sensor. I already bought the holesaw because i thought i had to drill the hole on mine too.
daves2369
RNS510,
Bluetooth 9w7,
Milltek Cat Back,
VWR Intake,
Cruise Control,
Parking sensors,
Post by daves2369 »
Just got around to doing this, If people have the red dash with a 36 pin connector you will need to use pin 34, 17 was already occupied.
