the_winner wrote:It has oil of course . But the rattle at the rough road it makes me to scare
If VAG were
really concerned about that, they would recall the cars. The ain't doing so.............. They would put preventative measures in place like the engine change of 24s4 campaign. They are doing that with 37G7 workshop campaign which will be done when a Scirocco next visits the dealership for service or gearbox issue.
Last thing VAG want is a lot of busted cars.
In late March I asked you for a VCDS Autoscan which I understand you can't do which was one way of determining where your DSG is in terms of build standard.
But I also asked in March .......
RW1 wrote:Have you had the software upgrade in the DSG (Auto-Trans - 02 Controller)?
Have you visited your dealer to check your Scirocco is up to date, as there are changes and some address your complaint. But they will only minmise it, not rirradicate it. The updates include changes to the gearbox software for rough roads. A 37G7 dealer visit will incorporate this.
When it is known what standard of DSG 7spd software you have, then we can understand whether the software update is still not the full solution.
And as I stated previously ..... I don't have the problem with my Scirocco nor two other units since I tested on earlier DSG 7 spd software standards. So its not universal.
